1982 merc 80 4 cyl thunderbolt spark plug wires needed
mercuryman80
I'm looking to see if anyone would know we're i can buy spark plug wires pre made for this setup they push in to the coil the #4 wire is 22" this is the closest I could find 84-813715A 1 - CABLE ASSEMBLY - IGNITION
Ignition Wire Kit thanks everyone keep your lines tight !
mercuryman80
Re: 1982 merc 80 4 cyl thunderbolt spark plug wires needed
I guess I'll make um lol
MikDee
Banned
You can make your own with Packard 440 wire. I'm guessing your old wires are glued in with epoxy, but can be removed with a little work. then epoxy them back in. If you can, run resistor spark plugs with the solid core wires, to prevent crossfire, arcing, or shocks, otherwise the spark will follow the easiest path to ground!
oldman570
From my checking on parts needed, it looks like the 84-813715A 1 wire kit is the one you need. A call to the dealer should get you all the info as to the length of all the wires before ordering them. JMO
Oldman570
Are all 4 plug wires bad ?----These wires are quite well made.---------Running problems with the motor ?
