Blueghost924
Thread starter- Joined
- Sep 19, 2013
- 250
As a couple of folks know, I've been trying to get my 1982 Mercruiser 470 up and running. A couple of months ago, I performed a compression test on all 4 cylinders and came up with numbers greater than 100 psi. Tonight I was thinking that I may have not performed the test exactly as outlined in the bulletin (I don't think I have all 4 plugs out or the throttle may not have been wide open).
I still can't get it started, so tonight I decided to re-perform the compression check. I made sure that all plugs were out, the coil was grounded and the throttle plate and choke plates were wide open with the spark arrester removed. Keep in mind this was a compression test on a cold engine (just like it was being started for the first time that day). I also had my SeaDoo fogging oil spray can on hand to see if that would make a difference after the first cold run. Here's what I got:
First run without using fogging oil:
#1 - 30 psi
#2 - 90 psi
#3 - 100 psi
#4 - 95 psi
Second run with fogging oil:
#1 - 33 psi
#2 - 95 psi
#3 - 100 psi
#4 - 95 psi
This is not good, and I'm surprised that #1 is that low (compared to what I thought I got a couple of months ago). My initial thought is there's a "remote" chance my compression tester is off, but it's only 8 months old, and is in good shape. Maybe I'm in fantasy land. Just for kicks, I may rent another compression tester from the local auto shop (like AutoZone) just out of curiosity. But it looks like I'm done for. I've looked at overhaul kits (including all the gaskets), and they're not cheap.
#1 - 30 psi
#2 - 90 psi
#3 - 100 psi
#4 - 95 psi
#1 - 33 psi
#2 - 95 psi
#3 - 100 psi
#4 - 95 psi
