goosemanhnt4fud
Thread starter- Joined
- Jul 13, 2009
- 20
Yesterday morning I took the boat out and it ran fine. Yesterday afternoon I took it out again, and it would not start. Today I tried to trouble shoot it. This is what I did:
1. Fuel pump is working, removed the line from pump to carbs,(carbs were cleaned two weeks ago) and it is squirting out gas.
2. Compression check is 146/146/147
3. I removed the spark plugs, and they were dry. I squirted some fuel in the #1 and #2 cylinders and tried to start it, but it would not fire.
4. I made sure the kill switch was in the run position.
5. The inline fuse on the hot wire that goes to the rectifier, fuse is good, and as I attempt to start the yellow wire that goes to the stator has power. (the stator does have some dry rotted wires)
6. all three spark plugs are new
7. Took a spark plug out, and turned over the motor and saw no spark.
What is my next step? Is there anything else I should look for?
Thanks in advance.
Thanks in advance.
