Charlie61
Thread starter- Joined
- Jul 27, 2011
- 253
hello again just got motor running after replacing almost all electrice parts . starts normal, can put it in grear still runs normal. When I go to throttle up it dies . So I throttle very slow and let it run there about 30 sec. the rpm will go up. I keep doing this untill I get in to a higher rpm and will run great. if it had wings it would fly. if I throttle up faster and hit the chock as I'm going higher it will work and run great at hi rpm.
This is telling me it needing more fuel in throttling up!
I did timing by the manual it did not work for me to will.
I like to know if I could ajust the carbs, or ajust the linkage going to timing, which do you think would work ?
Thank again
Thank again
