1983 35hp problem
jeremyswallace
the problem that i am having it that when i am going down the lake it doesnt matter how fast i am going. i get either a mis or like something is slipping. I am assuming that it is something like the clutch but before i get into the lower unit. was kinda looking for some tips on anything to check before i do that.
thank you jeremy
wilde1j
Re: 1983 35hp problem
If it happens smoothly, likely a spun prop hub.
Panfishangler1
I think I may have the same issue with my Johnson evinrude 15hp 1983. I posted my problem on another forum and someone said the same thing about my motor. How do you examine this spun prop and how can you fix the issue?
wilde1j
Mark the inner and outer prop hubs with an indelible marker, run the engine in the water, under load and examine marks. If they've moved relative to each other, hub is spun. Take prop to a prop shop to have it rehubbed.
jeremyswallace
i wouldnt say it is smoothly it is a tiller motor and it is kinda more of a jerk. I mean you can see the motor jump
wilde1j
Likely bad clutch dog and fwd gear. If someone has messed with shift cable adjustment, could be that instead.
jeremyswallace
thank you i was also thinking clutch dog just trying to get second thoughts
