1983 50 hp merc carb. problem I think
mmarr
I have a 1983 50 hp merc, I have had the carbs rebuilt several times over the past few years but always causing a problem. I can crank the motor and it will idle but when i put it under a load it will sputter and only run at minimal speed, but if I keep squeezing the squeeze bulb fast enough it will run fine. I took it to a mechanic again today he said it was a problem with those carbs on that model motor after a certain age. he suggested buying new carbs but they are $200+ each I dont want to spend that kind of money on an old motor. any suggestions? Thanks
Yepblaze
Re: 1983 50 hp merc carb. problem I think
Sounds like you might try going through the fuel pump(s) with new diaphrams, and check valves.
phatmanmike
that is good advice. that would be my choice.<br /><br />the pump kits are fairly cheap and very easy and strait forward to install.<br /><br />mine were about 12 dollars and i got a great deal for them at mercruiserparts.com
mmarr
thanks you guys for the response I think I'll try that first.
tengals123
yeah, sounds like that might be the problem. cheers
