DeepwoodTracker
Thread starter- Joined
- Jun 2, 2020
- 21
1983 Johnson 2 stroke 50hp
50TELCTA
Ran fine one time this year, after that I have had a constant problem with some irregular ones.
I have no Tach hooked up but I am going to put my Flukes RPM jigger attachment on it.
I have a new 2020 Controler with new cables all perfectly aligned and adjusted.
THE ISSUE!
when cold I can turn it on and GO! and it will work. But shortly after if I go below half throttle it will not want to go higher than half throttle again I sit at the stalling threshold till it makes a clean sound and then I can pin it again, if I go below half I have to fight the stall at half throttle religiously.
erratic idle on muffs, and finally the other day I was full throttle from leaving the landing, wanted to get to the other side then just puts around and about a quarter into the trip it just died off, will not start ect.
new parts
Fuel pump
coils
wires
plugs
power pack
rectifier
primer bulb
fuel lines between carbs and choke
fuel lines and connectors from tank to motor
lines from pump to carb connections/Ts
cleaned an blew out every orifices on carbs
sync carbs
temp sensor is no existent
water from the tell tale
Cleaned up all wiring (every connection double checked and secured for any grounding issues)
I am at a Total loss.
compression is also 140 each and consistent
can place hand on top of head when it shut down on me.
going to check telltale temperature to see if water is cycling through head tomorrow.
50TELCTA
THE ISSUE!
new parts
Fuel pump
coils
wires
plugs
power pack
rectifier
primer bulb
sync carbs
