larry.mahoney
- Joined
- Apr 15, 2012
- 12
Engine has 115 psi compression on all cylinders. Appears the float is bad far right picture. Right carb in pictures before & left after rebuild. Carbs were flooding & engine ran poorly now will only start with starting fluid and die. Replace float, needle valve & idle screw on both carbs. Fuel bulb has pressure & gas. Do I have the float upside down?
What did I do wrong?
Mercury outboard serial no. 6382441 with quicksilver kit 812953 it super-seeded 8982 kit.
Thank you
Thank you
