1983 70HP fuel problem
bcbrad87
When cold the motor won't start unless you remove a spark plug and put fuel in the cylinder. Once it starts then it runs fine and when warm you can shut off and it'll start again no problem.
The prime bulb is pumped and I have removed the gas line and the fuel pump is moving some gas.Would a weak fuel pump cause this or is there something else?
