redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,472
Just double checked to make sure I ordered the correct prop and I did - even went with a OEM. Got it on and there is a slight rub when turning - just enough resistance to not allow a full spin if I just flicked it. Appears to be rubbing the motor where they join. Put the old back on and no rubbing (no part # so not an EOM). The OEM is about a 16th of an inch wider by my measuring. I've spun it about 75 times and it appears to not even rubbing the new prop paint off, just has a little color to it. Can not see any discernable variation on the lower unit casing. I did have to use different spacers - the first one on whatever its called is much thinner than the one that was on there and with the old one on the outer spacer (the one with teeth) didn't grab. I've been boating 40 years and this is my first time pulling a prop aout.
Thoughts?
Thoughts?
