I recently got my 1983 Force 85hp running. I also put in a new impeller. Drained the old black gear oil and refilled with new gear oil. I wanted to move the Bayliner to the front drive so I tilted the motor to 45 degrees and brough it around.
I let the motor back down to its normal position when I noticed black oil leaking from under the plate where the bolts hold the lower unit up. There are some small holes next to the bolts I mentioned....this is where the oil is coming from. It leaks real slow then stops.
Can someone tell me what I did ? Ive been test running it in a large trash can and have noticed the water becomes filmy , oily and yellowish only after 5-10 minutes of idling
