Mercury1150
Thread starter- Joined
- Sep 22, 2014
- 5
So I recently went and purchased a 1983 merc 150. Did what I thought was good enough check over before buying it, compression was good 120-125psi every hole it showed good blue spark on all 6 plugs. The previous owner said it started running bad one day so they took it to a shop and had stator and switch boxes replaced. They then took it out to the lake at it still ran bad. So the same shop said they needed to rebuild the fuel system, the cost of that was too high for him ( apparently the boat it was on was completely rotten) and that’s when I come into the picture. I took the engine home rebuilt all the carbs and the fuel pump hooked it up on my boat and it still runs poorly… verified spark with a timing light on all 6 but when I pull the spark plugs they all look wet and don’t appear to be firing well. Ohm tested the trigger, stator and coils, all six coils were low but the stator and trigger were perfectly in spec, this leads to my question. Is it possible that all six coils could go bad at once and still show good spark? Am I overthinking this?
Hopefully the attached video works, it runs ok on the muffs but will not plane the boat.
Any thoughts or previous experiences much appreciated !
