Supersportster
- Joined
- Oct 20, 2008
- 205
Hey, I have been having an issue where the motor runs great at high speeds, but slowly dies off if trolling.
I have tried all of the obvious, carb cleaning, check and replaced one cracked coil, tried different power pack taht was known to be good, used different gas tanks...
So finally I took it to a shop, and they said the compression is even on both cylinders, but a little lower then when its new???
Also they said my problem is that the thermo stats are stuck open and that is waht is causing my issue. They said the heads have to come off to replace the t-stats.
Does this sound correct? How big of a job is it for me to tackle?
thanks!
thanks!
