1983 force 125hp piston #s
last tourny of the year i lost compression in the #4 cylinder causing the engine not to idle, boat still ran 40mph before i knew it only had 20psi in the cylinder. anyway it appears the rings stuck and came through the piston top destrying the piston but did not harm the cylinder, no scoring on the cylinders but i plan on rebuilding it this winter and i need to know what everyone is rebuilding these motors with piston wise. im looking at going to wiesco pistons, im wondering if anyone knows the part numbers for the pistons that i need.
jerryjerry05
Re: 1983 force 125hp piston #s
Contact Wiseco they will give you the info you need.
No scoring at all??? Boy did you get lucky.J
Frank Acampora
Wiseco---800-321-1364
Piston Standard 3.3125 part #3129PS bearing kit W5216
They don't show either a Force or Chrysler for 1983 but it doeasn't matter: The 125 always had the 3.3125 bore
