Ski'nBlind
Thread starter- Joined
- Jun 20, 2010
- 32
Hi all,
I wanted to send out a shout to everyone that has posted about Mercury service and repair. I've been away from boating for a decade and just recently bought a Checkmate with said Merc "tower of power". This set up has been sitting for years and it took me weeks of searching this forum for answers. If you look hard enough this forum has way more info than my seloc manual but it works for quick reference.
I initially had a problem with "motor won't rev past 2500 rpm" like hundreds of others. I overlooked an issue when I bought the boat that some of the wiring (stator ac and pri. coil wires) looked good on inspection but completely fell apart and broke while testing. The engine would start and idle great in the driveway but had no power under load. I did the test of disconnecting the 2 yellow stator leads from the rectifier and the engine took off like a raped ape out on the water. There was some issues I found in my searchs here that some people think that since it's the charging system only it won't effect ignition......WRONG! In case there's someone out there with a similar problem it took a whole 5 minutes to figure out while at the dock.
The rectifier did not test bad with my fluke meter so I was a little surprised at the results myself. I also purchased a new CDI stator since I had done quite a bit of re-soldering wires just to be able to acurately test the ignition/ charging system.
I removed the idle stabilizer too after reading about that and am waiting for the rain to stop to go adjust the timing. Lots of very good information on this site!!
Thanks all
Thanks all
