1983 Mercury 115 setting wot timing?
toybuilder039
When doing a link and sync on my 115 Mercury inline6 it says to set the timing to 21 degrees btdc which I understand but says to err to side of caution. Does that mean you would be better to set at 22btdc or 20btdc?
jimmbo
Well, advancing the timing can, in theory, make an engine put out more power, right to the point of self destruction. Combustion chamber and cylinder head temp would be higher while exhaust gas temps would probably be cooler. Don't advance the timing past the spec. You can hear an auto/truck engine pinging, warning you of preignition and detonation. You'd never hear it when it happens in an outboard, the first sound of it happening is usually the last sound you will hear from that engine.
toybuilder039
Yeah I won't to set to safe side just didn't no which way that was. Thanks
