1983 Mercury 150
cleidson
Beautiful day on the lake just one problem. When the boat was running around 2600 rpms an alarm would sound. Now the strange thing about the situation is; when we wiggled the ignition key the alarm would stop. Any ideas?
CharlieB
Re: 1983 Mercury 150
When the key is first turned on and the alarm module is powered up, it gives a single beeeep.
An OIL alarm is a rapid beeping
An OVERHEAT alarm is a solid beeeeeeeeeeeeeeeeeeeeeeeeeep
You need to verify which you are hearing, since the ignition key is actually TWO switches in one, the first is a ground-to-kill in the off position, the second powers the alarm and accessories while ON.
You could have a poor switch, intermittently failing the power-on side, causing the alarm to signal it powering up. If this is so, you may also see gauges flickering as if you are flicking the power on-off-on.
Superjetjim
I have the sanme motor and mine doesn't beep When the key is inserted or when started, does that mean my control box has a problem?
Dukedog
'83, no oil injection. No injection, no beep at ign. on...........
