I have to admit I am more nervous about trying to remove the motor than any of the other things that have to be done to get this boat on the water again. I have seen several topics about lifting the motor and putting it on a stand but really nothing about disconnecting it and this has a lot of connections that don't seem to be obvious on how to disconnect them. Here the throttle cables go through this plastic block which has no give to it. I am guessing you take out the bolt that holds the clip both lines are going through and then unhook them from the lever they move then the plastic block would slide up. Is that right?
I am guessing these power the tilt from where whey are mounted. The motor will not turn left or right AT ALL when the steering wheel is turned, and it only turns a little ways before there is too much pressure to continue turning it. Is this normal when there is no power (the battery is missing) or should it be able to turn in which case something is holding the motor from turning. Since I can't turn the motor I can't really see how or where these wires go at the moment.
Here are the other big bundle of wires and I think the gas line (haven't followed it back to be sure that's what it is).
Where that bundle enters the engine compartment, they twist around stuff, some go to the other side of the motor to a terminal block, some go to points on this side of the engine. I should be able to get enough light to see where these go and disconnect them if this is the right way to do it. Or would it likely be easier to disconnect the wires at the panel and pull them through the bulkhead leaving them attached to the motor. That would mean taking the throttle apart and I haven't even looked at what that would involve.
I have already found a couple of wires that don't connect to anything. I was planning to take the boat to the marina to have the motor checked over after I get the floor replaced and put the motor back on so they have the whole thing to fix any wiring issues. It's been years since I did any kind of engine work and don't have the tools or books to use to figure it out so that part will probably be left to the professionals..... don't need a wiring fire because the PO did something funky and in my ignorance I repeat it when reassembling the electronics.
Any guidance on what and how to disconnect the motor prior to lifting it would be greatly appreciated.
