i bought a new sending unit because the old was no good to verify that i benched tested the old one and no reading benched tested the new one worked good. i then i tested the fuel gauge the way the manual says to do it and it worked good. so one would think everything should work but it didn't as soon as i attached the positive and the ground to sending unit the fuel gauge went right to full and i know for a fact the tank is only a 1/4 full so i pulled the sending unit out and tested it out of tank and same thing i attached the positive and the negative and the gauge went right to full, i then lifted the float to see what the needle would do and the needle moved farther ahead about a 1/8" as long as the wires are attached it stays at full. i checked all the wiring and everything seems to be good i have never touched the wires and it don't look like the previous owner did any wire work. So any input would be nice
