The timing of the the Primary Pick-Up is the subject.
All sources set the IDLE STOP to align the embosed arrow to the embosed line
With this complete, I have three sources of what the ignition timing should be at this point.
I have a SELOC manual that indicates 4-6 degrees BTDC.
I have info from a Forum (I can't relocate that forum, it has pictures marked up with arrows and text on how to do tiiming) that says the following as I quote.
Identify the 4 and 6 degree marks AFTER TDC - NOT BEFORE TDC so counter-clockwise to the 4-6 degreemarks from TDC.
Another source indicates that the engine idles with timing ATDC and as the cam touches the carb roller it would be TDC and then advances BTDC reaching a max of 20 degrees at cranking speed.
This engine starts every time and runs wide open and at all speeds below with one problem.
If I set the idle in neutral, it idles well.
If I set the idle with shift in forward, it idles well
The problem, I can't shift from neutral to forward or forward to netural and not have the engine stall.
It will restart with no problem.
