nebuhcanezzar
Thread starter- Joined
- Sep 15, 2020
- 8
I have a new to me 1984 Evinrude 185HP outboard on my 19 foot Grady White boat. I have struggled with getting any reliable performance out of this motor this whole season. I am hoping someone can help answer a few questions with some issues that I suspect may be putting my motor into SLOW mode. I apologize in advance if I use the wrong terminology, I am still learning. To assist in clarity I will add pictures when I get home tonight.
1. On the starboard side of my outboard at the top of the water cover on the cylinder there is a small port where I believe the thermostat would be located behind. This port has an opening in it by design. When I turn my motor on in short order a very steady stream of water shoots out of there. The water gets hot enough that I can't keep my hand under it. I am suspecting that either my thermostat is stuck in either a fully open or fully closed state. Or perhaps the bypass valve? behind it may be stuck. So my simple question to start would be is this normal for water to spraying out of there? Follow up question is it normal that this water be very hot but my telltale which also has a very steady stream seems to be the same temperature of the water that the boat motor is sitting in?
2. It appears that my VRO was bypassed. I suspect that it wasn't done correctly. I noticed one of the ports on the VRO was open not plugged at all so I have recently plugged that and the engine seems to sound a little less rough. On all the videos I have watched on how to bypass it shows disconnecting a half-moon electrical plug. On my motor I can't seem to locate that at all. It appears on my VRO there is no electrical plug coming from it at all. Is this just due to the age of my motor?
Thank you for anyone willing to respond with suggestions.
