lx.crowell
Thread starter- Joined
- Jul 12, 2012
- 42
This is my uncles boat it is a 1987 chris craft scropion with the 350 mercruiser. The other day had it out and it started to dog out, wide open the motor was acting like it was on 1/2 throttle, we assumed it was starving of gas so replaced the fuel filter/seperator and my uncle being my uncle decied to replace the plugs also. When we took it out again it was worse had a misfire like crazy and when you would try and plane it would backfire and it sounded like a lawn mower. Took it out put new wires on it tryed it no better, put a new coil cap and rotor on a little better but still had a horrible miss. To me sounded like a preignition checked the timing it was at about 10 BTDC at 800 RPMs. Also did check the firing order and that was corrrect, not sure where else to go now but into the carb.
