1984 35hp johnson mix ratio
oks
Hey all i just bought me a boat last week it is
my first boat i have ever owned i need to find
out the gas/oil Mix for a 35hp johnson 12gal
gas tank thanks by the way im new here .
tashasdaddy
Re: 1984 35hp johnson mix ratio
the ratio, is 50 parts gas, 1 part TC-W3 outboard motor oil. this is the easy way to figure it out. http://www.iboats.com/2_Cycle_Oil_M...73703934--**********.842593872--view_id.56142
that motor should burn about 3-3.5 gallon of fuel per hour and wide open throttle, so 12 gallons will last a good while. i would also add stabil to the mixture, to help keep the gas from getting old.
also change all your fuel line to alcohol resistant lines, if it has not been done. they will say alcohol resistant on them. Ethanol, deteriorates the old line and clogs the carborators.
kenmyfam
Welcome to iboats
Enjoy your new boat. You will find all the help you need out here. There are many true experts.
