1984 65 trim replacement
scottos
Hi everyone,first time here. I own a 1984 evinrude 65 commercial model,manual steering and tilt. Since new it has been a bear to raise the engine. Are there any power trim systems that can be installed on this model ? Thanks in advance.,scott
Honorary Supreme Mariner
Yes.-----From many 3 , 4 and 6 cylinder Johnson / Evinrude models
Use ----" fleabay " -----Make sure you get a fresh water one.----Get one with a " 2 wire motor " and get the box with relays and wiring.-----A complete blown up motor is the best option-----Not sure what is in your area.-----Lots in some fresh water areas.-----Salt water likely destroyed all of them where you are.
tphoyt
There is a 92 60 on Craigslist Cape Cod. I’m not sure it’s what you need but it might be worth looking into.
