Bikeluver43
Thread starter- Joined
- Jun 20, 2010
- 29
Hello all, its been a long time since I've posted mainly because my boat has been running very well for the past few years. Well she sat on the trailer for the entire season last summer with a few starts to make sure she was ok. I got fresh gas and oil, put a new battery (not needed but did for safe measure), and hit the key, like normal she fired right up. At first not all 3 cyl's were hitting but she coughed out of it. Off to the lake we went. Launched, took off and was driving for a good 15-20minutes mostly at cruising speed with full throttle only used to get up on plane. While on plane and cruising the motor started to die, sounding like it was out of gas which I new it wasn't. She stalled out, but started back up. Went to get going and she'd only run at slow speeds, anytime I'd try to give gas to get on plane she'd die back out almost sounding like I was flooding the engine. After a few restarts it would only start if I choked it (has the push in key choke) while I gave it throttle in nuetral.
Things I checked:
- Fuel level was fine.
- Nothing caught on prop
- Remove flame arrestor cover and nothing clogging the carbs
- Fuel line is not kinked
- Fuel tank line to motor is new last season as is the ball
- Fuel primer ball was hard, never lost pressure running or starting
- Plugs are probably a season old.
What I'm thinking may be wrong - Carbs may have gummed up from sitting. I used fuel stabilizer before last season but nothing over the winter into this season. - Motor may need to be decarbed with SeaFoam? Possibly a clogged fuel filter or the screen in the fuel pump as I cannot find a fuel filter in the motor anywhere.
Looking for help! Thanks
Things I checked:
