Re: 1984 85 horse force outboard night mare
There are diagrams in the book that would show it, if that is what u mean.<br />Magnet; under flywheel is a series of magnets<br />glued underneath the flywheel. If one comes of, it wont run good.<br />Flywheel key; A piece of metal that fit into a slot in the crankshaft and the flywheel,that keeps them locked together. If it shears, it won't run good, or won't run period. It'll act like the timing is way out in some cases.<br />Twisted crank; Twisted Crankshaft at the flywheel's taper...Very rare condition, but <br />will cause a constant miss, or "out-of-timing" condition.<br />Is this the same engine as the one with all the CD modules failing?
