I have replaced the impeller on this motor. It runs great after you let it warm up for a while... I was crusing at a slow idle and it the engine just stopped. Kind of a hard stop shook the boat a little... Was able to start it again but when I put it in gear and idled again it did the same thing. Every once in a while it would do it while it was in neutral as well. If I went from Neutral to drive fairly quick I would have no problems. <br /><br />Motor history:: All I know is that it sat without running for a few years (2-3). There is gas in the gas tank that sat that long as well. could this be my problem. Bad Gas. Should I run the gas out or drain it?? It also puffs alot of white smoke. Could it be running to rich or lean? if so how do I Adjust. <br /><br />Thanks in advance for your help.. Everyone in this forum has been great and I really Really appericiate it... Thanks Mike
