omc_parted
- Joined
- Jul 12, 2014
- 74
First off, thanks to Friscoboater for giving me the basics (and courage) to attempt this job. Had a block crack last winter, so I rebuilt it, got it running, and am now looking at the rest of the boat. I knew the motor mounts were gone cause I had to use bolts to hold down the trim motors (instead of lag bolts). The interim housing was lagged down ok. Surprisingly, the transom is solid. However, the stringers are the consistency of leaves. Have removed the deck (up to the helm) trying to find the end of the rot. It hasn't ended. Even the boxes on the sides are rotten. Noticed that a lot of the fiberglass holding it all together is 4 inch tabbing
Have uploaded some pics. Will follow up as I get deeper into this rabbit hole.
