1984 evinrude 6hp dropping power while full throttle
kevinstan
Just checked compression. Both were right at 95 even. So now that I have ruled that out, what should I check next ? I have everything to replace the tank and hoses and primer bulb so that's next, but if that doesn't fix it then ??
lindy46
The fact that it runs if you raise up the fuel tank makes me think it's a weak fuel pump. Was it new or rebuilt?
ondarvr
When you have an electrical problem the sound and RPM's typical change like someone flipped a switch, when it's a fuel problem the RPM's normally chnage a little slower and smoothly. It sounds like a coil failing from your description.
A leaking head gasket typically doesn't spray water anywhere and is not noticable from the outside, but it can force exhaust into the cooling water jacket, and depending on the size of the leak it may not allow any water to enter the block and you just see steam, or intermittent water flow with spurting and some steam.
Tim Frank
You've verified compression, now check that spark will jump a 5/16" gap......use a proper spark tester.
kevinstan
I will get a spark tester and verify spark next. I will post an update once I do.
