jbhasaboat
Thread starter- Joined
- Jun 29, 2011
- 24
I've got an 70hp 1984 Evinrude model E70TLCRD that isn't firing on the top cylinder. If I pull the plug wire on that cylinder there is not change to the motor and if I cover the carb with my hand the motor speeds up instead of choking like the other carbs do. I have tested the spark which is good, checked the fuel lines and replaced a few, replaced the fuel pump , rebuilt the crabs, done a compression check which shows 115 across all cylinders and that top spark plug when I pulled it had oil on it so i'm pretty sure its getting gas. I'm stumped on where to look next so any input would be appreciated!
