Firefighterfox
Thread starter- Joined
- Sep 10, 2019
- 7
1984 Force 125hp
September 20th, 2019, 03:07 PM
I'm trying to help a friend with his boat motor. I'm mechanically minded but the throttle and gear cable syncronization is too much. I've seen on one of the forums here that refers to a discussion where you have described the process. I have spent the last 3 hours trying to find it, with no success. Would you mind giving me some direction. I didn't want to start a new forum if one is already available.
Just a brief history of the motor in question: it's been sitting for a out 10 years. It has been started and run a few times during that time, but not run in n the water. The owner took the boat to a "boat mechanic" to have the carbs rebuilt and a new impeller put in. After the repairs were done he took it to the lake. He could not get it started. After removing the engine cover he was able to manually choke the motor and it started. (later he noticed that the choke solenoid bracket was not bolted on one side. After the motor had warmed up he put it in gear and he headed away from the dock. When he tried to accelerate the rpm's would barely build. He noted that the control was very stiff but as he applied excessive pressure the speed came up a little. Eventually the throttle cable broke off at the controller.
note: the cable had no rust, corrosion or binding.
He bought a new cable (exact replacement). At that point he realized that the newly installed cable was also in a bind. This is where I came, in after a few minutes realized that the throttle linkage step was binding on the gear linkage step. After about 8 hours of chasing the problem and screwing with anything that would turn or adjust I gave up. My conclusion is that the mechanic probably got something out of sync when he worked on the carbs and lower unit.
Well that's the end of this long story. Perhaps you will be able to help give it a Happy Ending.
Thanks for your time and advise.
Firefighterfox
Firefighterfox
