rolmops
- Joined
- Feb 24, 2002
- 5,558
So I took her fir her first test run after the rebuild and everything seemed dandy,she started well and she was running smooth. I had her running at 12/14/16 hundred and so on until 2000 rpm and it sounded real sweet. Next I tried a bit faster, but she would not go over 3200 rpm,this is with a 15/19 prop, so I figured I should try with a 15/15 although I am told that this engine is strong enough to push this roughly 3000 pound boat at 4500 rpm with a 19 pitch.
Then the bad stuff started happening.
All of a sudden the rpm gauge was all over the place (vibrating above 3000 rpm going back and forth while I did maybe 2000 and later only 1200) and the engine started to bug down and did some coughing and back firing (not strong but more like choking). I shut her off and let her sit for a minute,then turned the key and she started right back up,but after revving her up to 1200 rpm she started doing the same thing again.
My suspicions were that the timing had gone crazy, now I am more inclined to think that the distributor cap may be cracked (this is an electronic ignition with distributor).
In short,before I start throwing hammers, I need words of wisdom and advice. So please, if you have any wise words,I need them.
Cornelis.
Cornelis.
