I just got a 115 johnson v4 it came with 1 harness that hooks to the starter and had black plug that plugs inside motor that runs from throttle control then another that has key harness that has a red plug that i have no idea where it plugs to.
you cannot use the control box and the black electrical plug wiring harness on that 1984 115hp engine!
You must have a control box that has the wuring harness with a red electrical plug to correspond with the red plug wiring harness on the engine.
What is the model number of that engine?
last question for you it has no wire for starter or a ground it just has red plug running to a key separate from the key on controls
the red plug has wires running to key only
the black plug has wires to starter and ground and controlsView attachment 196357View attachment 196358View attachment 196359
i found out the black actually has red tip might just be dirty but why two big plugs
