1984 Johnson 60hp shift rod adjustment height
Willie468
Good morning all hoping to get a bit of help I had to replace my gears in my lower unit and now I am trying to figure out what my proper shift rod height is I believe it’s a short shaft however I would take the adjustments both for a short and long just so I can be sure once I measure the rod itself. The motor is a 1984 Johnson 60hp model number J60TLCRE. Any help would be greatly appreciated.
The model # indicates that your motor is in fact a LONG shaft.----It is set at 20-29/32" on your motor.
Willie468
I just found a post on how to read model number meaning the L means long which indicates 20” however I still don’t know what the shift rod height should be set at racerone
Willie468
Post # 2 clearly shows the dimension !
Thank you however before the height adjustment wasn’t included in the post that I could see so I apologize do you know non imperial number I am going to make a height adjustment tool from a yardstick so it should be 20.3 or something similar? I really appreciate all the help racerone
I believe you should know some grade 4 math here !---Do the calculation , perhaps even on your phone.
Willie468
Ok well clearly I’m just dumb and my lower unit will probably fail because I have no idea how to convert this over. Thanks for the help haha what a helpful forum
Can you divide 32 into 29 ?----Nobody hands out any beer tokens for top notch advice here.----And sorry , i do not know what tools and knowledge are in your workshop ??
Willie468
Not asking for handout just trying to fix my boat to enjoy sometime on it thought that’s the point of a forum is to help people get back to what they enjoy doing I get that it’s .90625 inches don’t get how that falls on a yard stick
29/32" I think.----Or perhaps you need a better quality measuring device.----Or put your own marks on the yard stick.----Very easy I think.
Willie468
Ok I totally over thought this and I apologize I feel pretty dumb after realizing how to measure out 29/32 lol thanks racerone for challenging me to figure it out and realize the simple measurement I was overthinking
