1984 Johnson 70hp will not reach high rpm
JPRidley
My 1984 70hp 3 cylinder Johnson starts easily, will idle very smoothly, and initially accelerates well but refuses to accelerate into high rpm and will not even plane out. I have rebuilt the carbs, checked and rechecked the high speed jets, replaced the plugs, checked and replaced all the fuel lines, cleaned the fuel pump filter, made sure the gas tank is vented, made sure it is running new gas with 50:1 mixture, checked the mechanical throttle linkage for correct settings so that the carbs are opened up all the way when the throttle lever is pressed all the way, run compression checks on all three cylinders - all are within 15 lbs of each other with 130, 135, and 140, and I have checked the stator output and the rectifier/regulator output and all seem to be within specs. Ok Ladies, what could I been missing here? This is very strange and any assistance or thoughts would be most appreciated. It ran great last year.
22E6441
Re: 1984 Johnson 70hp will not reach high rpm
I'm researching a similar problem with my engine.
Your engine may be going into SLOW.
Speed Limiting Overheat Warning
Not sure about your motor, but I can apparently disconnect a tan coloured wire that goes to the top of my motor to unplug the sensor for testing purposes.
JPRidley
Thanks for the suggestion. I will try this. Can you recommend a source for the Thermasticks and a sensor if necessary?:)
JPRidley
My wiring diagram does not show a SLOW sensor. It does show a temp switch which is connected to a horn circuit - but I do not see a connection to the power pack or the coils. Are you sure that an 84 has a SLOW circuit?
countvlad
are yo sure you are firing on all cylinders?
JPRidley
Does the Stator or the Power Pack or the Coils have a "high RPM" circuit or awareness? If so I cannot find documentation of this so far. I have seen this same symptom discussed in many other threads - but so far no real solid solutions - mostly just a bunch of carb and fuel line related guesses.
tashasdaddy
timing and linc n sinc. did you remove all the jets and clean them and the passages, and blow out the pick up tube in center of carb? you have 3 jets in those carbs, low, mid and high speed.
