JoshKeller84
Thread starter- Joined
- Jul 2, 2010
- 220
J75ECRD
got this motor with a boat i bought to use with my current motor.. its a 75/50 1984 3 cylinder johnson jet. top two cylinders are 135 psi, bottom is 30 psi. pulled the head and discovered this. The bore looks surprisingly good. I havent torn it down yet (will happen this winter after fishing), but am I looking at a ring broke and bounced around the cylinder, or possibly a reed? Something way worse?
Cylinder bore looks surprisingly good from what I can see moving the flywheel. Just a spot of rust on the bottom. Also is there a way to look at the piston and see if its oversized without pulling it? Would it say it on the crown? All I see is "75 UP"
I have rebuild a 1984 115 johnson v4 from the ground up, will this motor be of similar difficulty? thanks!
