1984 johnson, " good spark on all 4 cylinders but no power on 1 bank"!!!
johnhawg
HELP! i bought a 1984 baja with a 115 johnson. it seemed to run great with muffs in the yard, but when i but it in the lake it would not go fast enough to even make a wake......
i looked at the motor with a friend and found a couple of problems that i have no ideal about fixing. to make a long story short, its got good compression 106 on all 4 cyls, good spark on all 4 also, "even checked @ 7/16 gap". but one bank of cylinders is not running! and it appears as if it changes from the left to right bank. " i found this by disconnecting the plug wires one at a time, " motor runs with both plugs on left bank disconnected" but as soon as i disconnect any plug from right bank motor stops".
could this be a timeing problem? carbs are rebuilt. and again, " all 4 cylinders have good spark all the time"
johnhawg
Re: 1984 johnson, " good spark on all 4 cylinders but no power on 1 bank"!!!
i sure could use some help
PS94
Well, if you've got spark, and compression, you'll need some fuel..Just cuz the carbs were rebuilt doesn't mean they work correctly!!
kenmyfam
Great point.
How is the fuel delivery from the pump ???
johnhawg
seems like i got good gas, if bad, why only the lt bank of cylinders not running instead of top or bottom two?
johnhawg
wondering if i need to take it to a shop, im really wanting to use the boat this weekend before i deploy over seas.
kenmyfam
If you are in a hurry then you may want to see if someone can help you out.
All the best to you overseas.
