Re: 1984 merc 115 reed valves
Last spring ignition was erratic on all cylinders, finally replaced Stator and both Switch Boxes.
The Idle Stabilizer was removed.
At this point the ignition was looking great. All cylinders were equal and I had a great steady spark on all cylinders looking at the spark with the plugs outside the engine.
Compression on all cylinders 90-100 letting it rev about 5 times.
Rebuilt all carbs.
Timing was done very carefully to the instructions.
Lake trials produced the following result.
I could adjust the carbs to idle great, however I could not accelerate without stalling unless done very carefully.
I also could adjust the carbs so the acceleration was great, however the motor would idle only a very short time.
We had to make our annual Green River ? Colorado River 180 mile trip.
The situation on the trip was as follows.
Once up to about 2500 RPM, we were in great shape at any speed above that but could not slow down much without stalling.
Restarting was a nightmare, always wondered if it would happen. And when it did, it had to be nursed to get it up to an RPM where it would run well.
I did no more work on it last year, also did not make any other trips.
So here I am getting ready for the same trip this year.
So in answer to the question, I believe the only thing I have not checked is the reed valves.
Before I wanted to open up the power head I wanted to know what I was in to so I would have everything I need before starting.
Long answer but thanks for responding .
