1984 merc 90 hp starts but wont turn off
endurance
Change the key ignition on 90 hp with a force key switch. Starts but wont turn off any help would be great
endurance
I used another harness before and was able to stop and start motor i think its the wiring. The key ignition i switch to was working fine b4
enginepower
Your kill switch wire probably isn't grounded or your wiring isn't correct
Texasmark
I don't know when Merc changed colors but on the later models (3 cyl 90) the CDI modules each have a yellow/black stripe (or black/yellow stripe if you don't see it...one goes to kill the CDI the other goes to the fuel enhancement/choke solenoid)....forget which and my manual is gone.
In the control box, this wire is grounded (connected to battery -) when the key is in the OFF position and as such grounds the triggers to the CDI modules, thus killing the ignition and stopping the engine. Since you changed harnesses, problem is likely to be there. It could be a corroded pin in a connector, or a broken wire,
