1984 Mercruiser 265 (5.0 L V8, GM)
deputyb
I have googled the snot out of this and can't locate an answer. I have the above engine in an 84 Cruisers Inc 22' Barnegat. It quit charging the batteries. (new this year) So I replaced the alternator with a one wire unit and still shows no voltage at alt. post. wire from this post runs to a box (coil? transformer?) marked Battery (wire to battery now jumped to here) and the other big connector says Alt. a ground wire a back of this box is grounded. what is this box? other than possibly a bad alternator (new from NAPA), why isn't the battery charging. 10V shows pretty steady on dashboard volt meter. fishfinder says 8.4 to 10.8 volts. thanks guys.
One wire alternators should not be used in boats
Your alternator is either not sensing battery voltage, or the alternator isnt working.
Make sure every wire connection from the battery to the block to the alternator is clean and shiney
alldodge
Post a pic of the box, its probably an isolator and the diode inside has burned out
