1984 Mercruiser 3.0 140 hp questions
trabich
I have a 1984 VIP with the mercruiser 3.0 140hp motor. I have some knocking coming from the rockers and had a question. Is this model hydrolic or mechanical? If mechanical what do they need to be spaced at?
I am also getting ready to check the timing. Does anyone know what the timing needs to be set at? And, does the distributor in this year and model have points?
I really appreciate any help.
tupperj
Re: 1984 Mercruiser 3.0 140 hp questions
Trabich,
I've got an 86 3.0 that I've done a bit of work on recently.
Timing is 6 degrees BTDC.
You SHOULD have points, unless someone has changed things over to something like a Pertronix setup. Open the distributor and have a look. Also a good time to inspect the cap and rotor. Mine needed plug wires, I think they were original.
Lifters should be hydraulic.
Valve lash adjustment has been discussed quite a bit recently, and a search will give you better instructions than I can.
Anything else you need, ask. Lots of good info here.
Paul
