wcsd106
Thread starter- Joined
- Mar 27, 2010
- 182
First off... UGH... another year with a new set of problems on my aging 200HP Mercury engine, but the way I look at it, I fixed electrical problems last year and the motor ran like new... guess this year it's carb issues.
I have had the boat on the lake once already this year and ran without any issues. This afternoon I got the chance to go out again.
Problems:
1. The primer bulb didn't seem to get very hard, but it firmed up somewhat and I decided to try to start the engine.
2. When I went to start the engine, it turned over a few times and acted like it was going to start, but then I heard what can only be described as a backfire and turned around to see flames near the bottom of the engine. These flames were extinguished immediately using the fire extinguisher and I opened the cowling of the engine to inspect it for damage.
3. I saw no visible damage, but I did notice that there was fuel that appeared to be leaking from the bottom carburetor.
I did not make any further attempts to start the engine after this.. one fire on the water was enough for me and I am just grateful it was just some very small flames.
I will be doing a better inspection tomorrow to see what I can find wrong with the carbs.
The last time I inspected the spark plugs, it looked like my bottom two cylinders were getting a little too much fuel... I would assume this is probably connected to my carb problem as well.
Since it's been at least 10 years since the carbs have been rebuilt, would it necessarily be a bad thing to go ahead and pull them and rebuild all 3 carbs?
Any ideas, as always, are appreciated. Thank You
Problems:
