1984 model 110 help with time and sync
Yachtzee
Can someone fill me in on how to time and sync my 1984 model 110 (9.8 hp)
I use it s a kicker and it used to push my boat along and 7 to 10 mph.
The plastic throttle lever on top of the carb broke, I got a new piece. I assume it needs to be put on and adjusted so that it allows the butterfly to close all the way with the twist grip in the idle position and the follower just almost touching the cam in that position. I did not change anything else but all I get out if it now is about 3 MPH wide open.
With the throttle all the way open and the lever hitting the max advance screw, the butterfly is only 3/4 of the way open.
if I back the stop screw out, I can get the butterfly to open all the way, but I fear the timing may be too advanced.
Any ideas on what changed or how to get it back into specs?
I have a manual but it stops at 1971 and it's all different for the 84
