1984 ranger 335v
jrbohannon
I bought a 1984 ranger 335v from a storage lot and am in the process of restoring it. there is what looks like a through hull transducer in the bilge but it doesn't look like it goes all the way through the hull. does anyone know what this is. also it has 2 slide levers to open and close livewells but they are no good. where can i get replacement valves. both slide cables work ok.
Teamster
Re: 1984 ranger 335v
Thru hull transducers on a glass boat don't go all the way threw the hull, They are glassed into the bottom of the boat and shoot thru the hull,.......
Send an e-mail to Ranger about the livewell valves, They would know better than anyone else,...
wet willy 24
Try th marine they made the original livewell parts and they are still avalible
f-106-j75
Hi, i ordered a 1958 chevy heater valve from auto zone ( $20.00 ) when it comes in, i'll let you know if it works. 5/8" inlet and outlet nipples. looks pretty much like the same valve.
