msu_sports
Thread starter- Joined
- Jun 9, 2011
- 9
This is my first post here so I am hoping I can get some advice. I have been rebuilding an '84 SeaRay Seville 5.6 BowRider with a Mercruiser 120 in it. I have two seats left to recover but wanted to check out the engine after I had done some work to the lower unit. I tested the engine with earmuffs on and with some adjustments at the carb everything was running smooth, no issues. I took it out to the lake and it was in the water for 25mins (engine off) with no problems. After starting the engine and running around the lake a short bit I noticed a bit of water in the bilge and then found the water was running in near the hose for the water pump behind the engine but I couldn't quite see exactly where. I turned off the engine and the water quit running. Engine on and water started running again. I checked again with earmuffs on and no water issues occured. Any ideas on what the problem is and what i should look at first? Thanks.
