1984 Starcraft 16ft Glutton for Punishment [Splashed July 2019]
Status
Not open for further replies.
jbcurt00
@jbcurt00
Can you please move this thread to the Starcraft Rebuild forum?
Thanks
SHSU
Moved
Just to be clear, this was in the Resto/Rebuild forum. This is the Starcraft Owners forum, so there may be a glass boat or 2 as well. Some (many? most?) SC owners choose to document their resto here, esp the tin boat fellas
Either forum is a good place to document your work.
Occasionally, even though they are active members, some tin boat guys will miss a new boat/rebuild/topic because its in the main resto forum, rather then here.
W the current vB5 forum software Todays Posts feature, I use that new posts list as my bookmark for iboats, and rarely go the the main forum or any specific forum/sub-forum homepage. So no matter what forum, if a new post is made in ANY topic ANYWHERE on the forum, I see them listed in the Todays Posts list.
Unless I go 24hrs w out checking in, I dont miss many new posts or the updates to that topics.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Moved
Yep, this is where I wanted it. Appreciate the move
SHSU
So I got my knee bracket back from the welder and really like what he did. I will post pictures once I can, but he made a comment I wanted to run by ya'll. I know the consensus is not to use bed liner; however, he suggested I paint the knee bracket to prevent future oxidation of it with bed liner. What do ya'll think? Good idea, bad idea, indifferent...
Watermann
You asked for it. :lol: I have a couple questions. Why would anyone care if unseen aluminum oxidizes? Why do so many people think pick up truck bedliner is the savior of aluminum boats? Bottom line is bedliner will fail and it can cause serious corrosion issues when it does.
The entire bottom of my SS is bare AL and it's a beautiful natural oxidized aluminum gray color now.
SHSU
LOL, I know I did!!!! Figured that would be the answer but ya never know until you ask :D
SHSU
As promised here are the pics of the knee bracket and additional backer for the exterior of the hull. Still have to do some final molding of the aluminum and redrill holes, but it gets me going in the right direction
On another note, do ya'll have the same drain plug design (see below)? Wondering if it can be cut off and another drain plug installed or should I just leave it alone?
Watermann
Knee brace looks well done :thumb:
A word of advice, don't bore the holes through the KB until you dry fit the transom wood and mark or drill through all the holes.
Both my SCs have that style of drain plug, they work fine. The only other option is a garboard plug style and most of them are dissimilar metal used in glass boats.
SHSU
For the KB, are you referring to redrilling all the holes or just the top 6 that will go through the transom?
So on the drain plug, leave it alone and use the old cork. LOL, Got it
Thanks
Watermann
Attach the KB foot to the bottom then, insert transom wood, drill the transom and clean KB at the same time. It's just so you don't have to worry about aligning the holes.
fetch
SHSU
Ah, now I understand. Much appreciated
SHSU
So I was looking at Blind rivets I would be using to secure flooring and such. I noticed that they have Aluminum with aluminum mandrel and stainless steel with stainless steel mandrel. The stainless steel has a much higher sheer and tensile strength. What kind should I get: Aluminum or Stainless steel? Not sure if the dissimilar metals outweigh the increase in strength.
SHSU
Watermann
1/4" blinds only come in dome head as far as I know but you could use them I suppose at more cost of course.
SHSU
I thought I saw them, but I when I went back it was only the 3/16 like you said. Looks like I will be using the 3/16th :D
sliver240
I used the 3/16th for the floor. Plenty good enough. Make sure you get long enough rivets for the job! Also double check length if you are going thru carpet covered flooring etc. Stainless rivets are a pain to drill out and are very grip range fussy. I've had them not pull the joint/seam tight if a tad too long.
SHSU
Thanks Silver. Good point on the taking the carpet into account. Didn't think about that. I will have to factor that in and quickly. I am looking to start doing some ordering today. Maybe I should just buy 5 different lengths..... My luck, the one length I don't buy is the one I will need LOL
Watermann
In the rivets sticky the blind rivet lengths listed for each decking thickness takes into account the deck covering and the material below deck they're attached to. Are you going to run the LF rivets through the carpet leaving the heads exposed? If so go with the listed rivet length for the decking thickness you're using.
SHSU
Thanks WM, I was looking at that and was thinking about adding an extra 1/16th, but will just follow your suggestion :D
Status
