1984 Starcraft SS180, 1984 Johnson 140 2 Stroke
budski
Hey Ron that large bilge cut out on the left was supposed to for the fill hose built in tank we decided not to put it in, the right side opening is for he drain and fill hoses for the live well, we will cover the left square opening with a piece of plate aluminum, that is where the 6 gallon portable gas tank will be, under the rear casting deck
FIGMO
Hey Bud,
I noticed that you are using carpet on the hull, and vinyl on the deck boards. Is that to keep the noise down?
budski
Hi Ron that isn't to keep the noise down but I suppose it might a bit, that's just the way we like to do it.
budski
We got the tops of the gunnels carpeted, and the rear deck cut out just in place for now, we still have to cut out for the splash well and storage and live well lids.
budski
[No message]
budski
We got the live well and storage openings cut out, going to use aluminum diamond plate for doors.
Watermann
Adding aft raised decking sure makes a huge difference in options and storage. :thumb:
budski
Sure does Rob, we got the tops and front of the rear deck carpeted.
budski
Got the bow and consoles done dry fitted.
budski
Thanks Rob, we got the rear casting deck secured and all the doors attached
budski
Thanks kc, we got the bow casting deck and the consoles secured the windshield dry fitted and the dashes fabricated.
budski
Forgot to mention we moved the consoles and windshield 5 inches forward giving us a bit more room in the main section..
Watermann
The more forward consoles is the way the V5 SS models are, not much room in the bow area but gives you more room for raised decks aft.
Sure looks roomy! :thumb:
fetch
budski
For sure Rob, but still quite a bit of room in the bow. the super sport is roomy enough in the bow anyway.
