1984 Suzuki DT115 DT 115hp Wiring Main Harness
Jetav8r
Hi All -
Still hoping this thread may find some help.
I have acquired a 1984 Suzuki DT115hp outboard in fair maybe good shape. .
It has good compression and the hydraulic/electric trim system works.
I want to see if this motor might run -or- (if not) a partout. But... I need to know the wire hookups from the engine plug so I can power up the ignition.
Obviously... not interested in spending 30+$ on this till I figure this out.
Any help here would be GREATLY appreciated (1 page of the elec schematic).
Please go here for bigger photos:
http://www.OceanNear.com/Files/suzuki.htm
Wires are:
Pink = Trim
Lt Blue = Trim
Orange = electric choke
Blue = ?
Brown = ?
Green (splits to 2 green) = ?
White = ?
Black = ?
Off White (with Black connected to Black) = ?
Jetav8r
Re: 1984 Suzuki DT115 DT 115hp Wiring Main Harness
WOW.... this is perfect. THANKS SO MUCH !!! - Dave
kandil
Re: 1984 Suzuki DT115 TD 115hp Wiring Main Harness
A big THANK YOU very useful post
Jetav8r
Ok guys. Here is the no kidding wiring diagram for the 1984 Suzuki DT115.
I've determined this motor has a bad CDI.
river_bouy
Thanks for the post Jetav8r, just what I needed.
One thing though, I can't read the fine print in the diagram. Any chance of posting a higher resolution image or a pdf document?
Jetav8r
Yes.... I know. That is the way I got it but.... right click and save photo. Then open with explorer and use ctrl + / - to zoom in and out. YOu can get what you need but takes some work and guessing.
The excel sheet I made cosolidates that info for just the ignition plug to engine.
