1984 yamaha 90 tach questions
levi_tsk
Ensign
ok so ive got a buddy that has this motor and despite going to MMI he cant figure out the wiring on the tach so firstly i need a wiring diagram
also the tach hes trying to hook up has the oil lights and wiring - i looked up the tach on boats dot net and that year model doesnt have these so im confused, can it be retro fitted?? and any help in this matter would be much apreciated
he "SAYS" it wont run right without the systems check (or whatever yamaha calls it) could this be true?
on the tach he has the lights come on but supposedly the needle doesnt work... i looked at it yesterday and the green and the black wire coming out of the control box werent hooked up to the tach at all... does this sound like the problem? the green plugs right in but the black has a male connector on both ends....
ive worked on all kinds of johnnyrudes and done some stuff on a M60B tohatsu but as of yet not familar wil the Yam's
99yam40
Re: 1984 yamaha 90 tach questions
It would help if you posted the model #s of tach and motor
On Yamaha Green is tach signal, black is ground, and blue is light
