1985 140 VRO vacuum line HELP
Blazinmonkey
i was hoping some one here could answer my questions on vacuum lines.
would a small vacuum line CRACK cause my 1985 140 johnson run out of fuel and stall, but idle fine?
also i broke the vacuum line T with an arrow on it behind the VRO where could i get a replacement?
thanks for any input...
bernd64
Re: 1985 140 VRO vacuum line HELP
you can get a new T at your local autoparts store and the vacuum line to
Blazinmonkey
thank you for the reply... i found the parts on Boats.net... Johnson 0394892 CHECK VALVE AY
do you think that cracked vacuum line would bog down & stall my motor?
